Component: LCD (Generic, 20x4) (Alphanumeric)
Revision as of 14:36, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Version 1.1
Category Alphanumeric
LCD (Generic, 20x4) component
LCD based on the standard 4 x 20 character unit.
Please click here to download the component source project: FC_Comp_Source_LCD_4X20.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LCD_4X20.fcfx
For the LCDs to work with the Flowcode LCD component they need to be connected up in 4-bit data mode.
The 4 data signals actually go to the upper data nibble on the LCD as shown below.
Displaying a numeric value
The LCD will retain the contents of the display, for high speed data we only want to have to write to the portion of the display that can change.
LCD Demo
Clear
Clear
ClearLine
ClearLine
- BYTE Line
The line to clear, zero being the first (top) line of the display
Command
Command
- BYTE instruction
Send a defined command to the LCD Screen. See datasheet for supported commands.
Cursor
Cursor
- BYTE x
Set the cursor position in the X plane, 0 is the left most cell
- BYTE y
Set the cursor position in the Y plane, 0 is the top most cell
PrintAscii
PrintAscii
- BYTE character
Holds an ascii value.
PrintFloat
PrintFloat
- FLOAT Number
- BYTE DecimalPlaces
PrintFormattedNumber
- ULONG Number
- BOOL Format
0=Signed, 1=Unsigned
Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767
- INT Number
PrintString
PrintString
- STRING Text
Enter the text or variable to print to the LCD
RAMWrite
RAMWrite
- BYTE Index
Values 0 to 7
- BYTE d0
- BYTE d1
- BYTE d2
- BYTE d3
- BYTE d4
- BYTE d5
- BYTE d6
- BYTE d7
RawSend
RawSend
Sends data to the LCD display
- BYTE data
The data byte to send to the LCD
- BOOL type
A boolean to indicate command type: true to write data, false to write a command
RemapCharacter
RemapCharacter
Assigns a remap character allowing the PrintString function to automatically swap between pre-defined characters. The characters can be custom (in the range 0-9) or can point to an existing character in the LCD character map.
- BYTE RemapIdx
Remap Index, Range: 0 to (Remap Characters - 1)
- BYTE SearchCharacter
Character to look for a replace
- BYTE ReplacementCharacter
New character value to use in place of the search character.
ScrollDisplay
ScrollDisplay
- BYTE Position
Holds the number of positions to shift the display
- BYTE Direction
0 = left, 1 = right
Start
Start
Startup routine required by the hardware device. Automatically clears the display after initialising.
Data 0 (11)
Data 1 (12)
Data 2 (13)
Data 3 (14)
Register Select (4)
Enable (6)
Component Label
Component Label Scale
Text Colour
Text Background
Colour surrounding the font characters drawn on the display
Background Colour
