Component: Output PWM (DSP Outputs)
Revision as of 14:35, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Version 1.2
Category DSP Outputs
Output PWM component
Allows the values from a buffer to be passed directly to an internal PWM output.
ControlPWM
ControlPWM
Enable or disable the PWM output, Disabled by default.
- BOOL State
0=Disable, 1=Enable
OutputPWM
OutputPWM
Outputs a single value from the input buffer appropriatley scaled to suit the PWM.
OutputPWMArray
OutputPWMArray
Outputs an array of values from the input buffer appropriatley scaled to suit the PWM.
- UINT Delay
Delay in microseconds between outputting each sample.
Connect To
PWM
PWM Channel selector
Alt Pin Enable
Alternative Pin Enable (if available on target device)
Port
Period Register
Defines the resolution of the PWM duty mark/space ratio. PWM duty can be between 0 (0%) and period (100%).
Prescaler Divide
Prescaler Divider value
PWM Timer
Timer associated with PWM to drive the output. Warning - All PWM channels linked to the same timer will share the same period and prescaler settings.
Period (uS)
Frequency (KHz)
Please click here to download the component source project: FC_Comp_Source_DSP_PWM.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_PWM.fcfx
