Component: Thermocouple (MAX31856) (Environmental)
| Category | Environmental |
Thermocouple (MAX31856) component
Component to interface the MAX31856 IC from MAXIM. Uses a standard 4-wire SPI interface to connect to the IC and collect the temperature. Compatible with different thermocouple types.
| Configures the SPI bus ready for communications. | |
ReadReference_Float
| ReadReference_Float | |
| Returns the reference temperature from the last sample as a floating point value in Degrees C. | |
ReadReference_Int
| ReadReference_Int | |
| Returns the reference temperature from the last sample as an integer value in Degrees C. | |
ReadThermocouple_Float
| ReadThermocouple_Float | |
| Returns the thermocouple temperature from the last sample as a floating point value in Degrees C. | |
ReadThermocouple_Int
| ReadThermocouple_Int | |
| Returns the thermocouple temperature from the last sample as an integer value in Degrees C. | |
Sample
| Sample | |
| Reads the memory of the MAX31855 IC and checks for errors. Must be called before any of the Read functions. Returns: 0=OK, 1=Open Circuit, 2=Under/Over Voltage, 3=Out of range | |
WriteColdJunctionOffset
WriteColdJunctionTemperature
Please click here to download the component source project: FC_Comp_Source_ThermocoupleMAX31856.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ThermocoupleMAX31856.fcfx
