Component: PIR Motion (Grove 101020020) (101020020) (Light)
Revision as of 14:36, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Version 8.0
Category Light
PIR Motion (Grove 101020020) component
PIR motion sensor component for digital output sensors. Simulates range sensitivity and output hold.
Version information
8, 8.0, 18-09-24, MW, Simulation bug, Fixed Switch and LED indicator not enabled
8, 8.0, 18-09-24, MW, Simulation only - Removed all properties and added a new Movement threshold % property
A simple example that shows the PIR in action.
PIR Example
Configures the I/O ready for the sensor to be sampled.
SampleSensor
SampleSensor
Returns the state of the sensor. Activated if movement detected in the sensor range.
SIG Pin
Pin connected to the sensor element of the photo transistor
Simulation only. Set threashold difference for detection of movement. E.g. if the slider was on 20 then moved to 40 the differnce is 20 PIR will only be triggered if Movement threshold is set below 20
Please click here to download the component source project: FC_Comp_Source_PIR_Motion_Sensor_Grove.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_PIR_Motion_Sensor_Grove.fcfx
