Component: Text (Graphical Manager Primitives)
Revision as of 14:36, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Category Graphical Manager Primitives
Text component
A text primtive used with the Graphical Manager on the GLCD Layout Editor panel. Useful when defining areas of the screen for text and touch.
GetID
GetID
Returns the assigned object/widget ID.
ModifyColour
ModifyColour
Changes the theme index of the selected Object or Widget.
- BYTE Index
0=Foreground, 1=Background, 2=Text, 3=Highlight
- BYTE R
- BYTE G
- BYTE B
- BOOL Redraw
ModifyPosition
ModifyPosition
Moves an existing object or Widget to absolute coordinates on the screen.
- INT X
- INT Y
- BOOL Relative
0=Absolute Positioning, 1=Relative Positioning
ModifyScale
ModifyScale
Changes the width and height of the selected Object or Widget.
- UINT Width
- UINT Height
SetTextFloat
SetTextFloat
Draws a floating point value with optional units onto an object or Widget location.
- FLOAT Number
- BYTE NumDP
Number of decimal points to display
- STRING Unit
Optional unit string to add after the numeric value. e.g. "g" or "s"
SetTextLabel
SetTextLabel
Draws a string onto an object or Widget location.
- STRING Text
Text string to set as the label
SetTextNumber
SetTextNumber
Draws an integer numerical value with optional units onto an object or Widget location.
- INT Number
- STRING Unit
Unit string to add after the numeric value. e.g. "g" or "s"
Line Width
Width of the outer border line in pixels
Line Colour
The colour of the outer border line
Fill Colour
The fill colour of the shape
Touch
Touchable
Determines if the display creator defined area responds to touches Touch is detected by using the DisplayManager::CheckForTouch macro with the X,Y coordinates of a touch
Text
Text
Optional default text to add to the inside of the shape
Font
GLCD font to use
Horizontal Alignment
Horizontal alignment of the text label inside the shape
Vertical Alignment
Vertical alignment of the text label inside the shape
Text Colour
The colour of the text
Please click here to download the component source project: FC_Comp_Source_DC_Text.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DC_Text.fcfx
