Component: Potentiometer (Slider) (Analog Input)
Revision as of 14:36, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Category Analog Input
Potentiometer (Slider) component
Please click here to download the component source project: FC_Comp_Source_Pot_Slider_Gdi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Pot_Slider_Gdi.fcfx
GetAverageByte
GetAverageByte
Read the ADC as a byte
- BYTE NumSamples
- BYTE DelayUs
GetAverageInt
GetAverageInt
Read the ADC at full bit depth
- BYTE NumSamples
- BYTE DelayUs
GetByte
GetByte
GetInt
GetInt
GetString
GetString
Reads the ADC as a direct voltage
- STRING Return
GetVoltage
GetVoltage
- FLOAT Return
Settings
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Bit Depth
Retain Value
Modified connection
Component Label
Show Connection Label
Show Pin Value
LabelColour
Colour Style
Style
