Component: ADC 24bit ADS1220 (Analog Input)
Revision as of 14:36, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA;"" to "class="mtx-class-propfolder"")
Category Analog Input
ADC 24bit ADS1220 component
A Precision Low power 24Bit SPI ADC 4 channel device with Programmable Gain Amplifier (PGA) and Data Rates up to 2 kSPS
Example use case of a 3-wire RTD to read high resolution and high accuracy temperature.
ADS1220_Test
Example circuit schematic complete with component values. RREF should be a high accuracy resistor with a low PPM.
Initialize the ADS1220 ADC with default settings
ReadRTDResistance
ReadRTDResistance
Reads the RTD sensor and returns resistance in ohms
- FLOAT Return
ReadRTDTemperature
ReadRTDTemperature
Reads the RTD sensor and returns temperature in degrees Celsius using linear approximation - matches GitHub library get_temperature_from_rtd_ohms_with_linear_approx
- FLOAT Return
SampleDiffRAW
SampleDiffRAW
Performs a differential ADC sample between two channels and returns 24-bit raw value. Not all channel combinations are possible, see datasheet p40 section MUX. Returns 0 if the channel selection is invalid.
- BYTE ChannelA
Positive channel: 0-3 (AN0-AN3)
- BYTE ChannelB
Negative channel: 0-3 (AN0-AN3)
- BYTE Gain
PGA Gain: 0=1x, 1=2x, 2=4x, 3=8x, 4=16x, 5=32x, 6=64x, 7=128x
- LONG Return
SampleDiffVolts
SampleDiffVolts
Performs a differential ADC sample and returns voltage in volts
- BYTE ChannelA
- BYTE ChannelB
- BYTE Gain
- FLOAT Return
SampleSglRaw
SampleSglRaw
Performs a single-ended ADC sample on the selected channel and returns 24-bit raw value
- BYTE Channel
Range: 0-3 (AN0-AN3)
- BYTE Gain
- LONG Return
SampleSglVolts
SampleSglVolts
Performs a single-ended ADC sample and returns voltage in volts
- BYTE Channel
- BYTE Gain
- FLOAT Return
SPI Channel selector
Prescale
Prescale option selector
MOSI
MOSI Remap Pin
MISO
MISO Remap Pin
CLK
CLK Remap Pin
CS / SS
Use Ready Pin
Use DRDY pin to detect when conversion is complete. If disabled, polling will be used.
DRDY Pin
Data Ready pin - goes low when conversion is complete
Configuration
Data Rate
Programmable Data Rate (SPS)
Operating Mode
Conversion Mode
PGA Gain
Programmable Gain Amplifier (PGA) gain setting
Voltage Reference
Voltage reference source
Reference Voltage
FIR Filter
IDAC Current (uA)
IDAC excitation current in microamperes. Typical values: 100, 250, 500, 750, 1000. Default: 250uA
I1MUX
I2MUX
RTD Configuration
RTD Type
RTD sensor type - determines base resistance at 0°C
RTD Configuration
Reference Resistor
High precision reference resistor value in ohms. Typically 400Ω for PT100 or 4000Ω for PT1000
Temperature Coefficient
Simulate Comms
Allows the communications to be simulated overriding the value on the panel slider controls.
Please click here to download the component source project: FC_Comp_Source_External_ADC24Bit_ADS1220.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_External_ADC24Bit_ADS1220.fcfx
