Component: DAC (Internal) (Analog Output)
Revision as of 14:36, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA;"" to "class="mtx-class-propfolder"")
Version 2.0
Category Analog Output
DAC (Internal) component
Provides access to the onboard digital to analog converter (DAC) peripheral allowing for simple analogue output. Often the DAC output will be very low current and will need amplification using external circuitry to drive anything useful.
Disable
Disable
Disables the DAC output.
Enable
Enable
Enables the DAC Output.
GetList
GetList
- STRING Name
- STRING Return
GetValue
GetValue
Gets the Name property value
- STRING Name
The name of the property
- STRING Return
SetOutput
SetOutput
Sets the output voltage of the DAC
- UINT DAC_Value
The value to output to the DAC
SetValue
SetValue
Sets the Value for the named property
- STRING Name
Name of property to update
- STRING Value
The new value for the property
DAC Channel number
DAC Output Pin
DAC Output Pin
Alt Pin
Vref Option
Vref Voltage
Control Bits
Resolution
Voltage Resolution
Please click here to download the component source project: FC_Comp_Source_DAC.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DAC.fcfx
