API Component.GetSolid
Revision as of 09:58, 17 June 2013 by JonnyW (talk | contribs) (XML import of updated API docs)
<sidebar>API contents</sidebar> Gets whether a component is checked in collision detections
Class hierarchy
Component
GetSolid
HANDLE Target
The component to read the state from
BOOL
Returns true if the operation is a success, else false
A solid component can collide with other solid objects on the panel. If an object is not solid, it will be ignored in collision tests.
  • Add to a calculation icon:
    result = ::Component.GetSolid(target)
