API Expand.VarName
Revision as of 09:58, 17 June 2013 by JonnyW (talk | contribs) (XML import of updated API docs)
<sidebar>API contents</sidebar> Expands a string to the name of a global variable used in the generated code
Class hierarchy
Expand
VarName
STRING Source
The variable name to expand
HANDLE Owner
A component that owns the variable
BOOL SizeName
Set true to return the expanded size define
STRING
  • Declare a variable 'result' of type STRING
  • Add to a calculation icon:
    result = ::Expand.VarName("source", owner, false)
