API Panel.Position.Animate
Revision as of 09:58, 17 June 2013 by JonnyW (talk | contribs) (XML import of updated API docs)
<sidebar>API contents</sidebar> Blends positions from two sources to a destination over time
Class hierarchy
Panel
Position
Animate
HANDLE Dest
HANDLE Start
The initial position of the animation
HANDLE End
The final position of the animation
UINT Millisecs
Time to take to perform the animation
The default value for this parameter is: 1000
This call animates between two objects, storing the result in a third Dest position. It performs the operation in the background over a specified time.
Interpolation from 0 to 1
The closely related Morph call performs this operation allowing for any point on the scale to be stepped to, but it must be called manually by the user to perform an animation.
Animations can be stopped using StopAnimate
  • Add to a calculation icon:
    ::Panel.Position.Animate(dest, start, end, millisecs)
