API Scope.SetBuffer
Revision as of 14:27, 9 August 2013 by JonnyW (talk | contribs) (XML import of API documentation)
<sidebar>API Contents</sidebar> Sets the contents of a snapshot stream
Class hierarchy
Scope
SetBuffer
HANDLE StreamH
A handle to a previously created datascope buffer
ULONG ElemBase
The index to start writing the data to in the buffer
ULONG ElemStep
The number of elements to tep after each write
The default value for this parameter is: 1
ARRAY Values
The buffer values to write, typically 0 to 1 floats
ULONG Elements
The max number of elements to write from Values
The default value for this parameter is: -1
  • Add to a calculation icon:
    ::Scope.SetBuffer(streamh, elembase, elemstep, _arrayvalues, elements)
