API Component.GetSolid
Revision as of 14:27, 9 August 2013 by JonnyW (talk | contribs) (XML import of API documentation)
<sidebar>API Contents</sidebar> Gets whether a component is checked in collision detections
Class hierarchy
Component
GetSolid
HANDLE Target
The component to read the state from
BOOL
Returns true if the operation is a success, else false
A solid component can collide with other solid objects on the panel. If an object is not solid, it will be ignored in collision tests.
  • Add to a calculation icon:
    result = ::Component.GetSolid(target)
