API Expand.VarName
Revision as of 15:35, 10 May 2013 by Admin (talk | contribs) (XML import API auto-gen)
<sidebar>API contents</sidebar> Expands a string to the name of a global variable used in the generated code
STRING Source
The variable name to expand
HANDLE Owner
A component that owns the variable
BOOL SizeName
Set true to return the expanded size define
STRING
  • Declare a variable 'result' of type STRING
  • Add to a calculation icon: result = ::Expand.VarName("source", owner, false)
