API Panel.Position.ScaleDown
Revision as of 14:27, 9 August 2013 by JonnyW (talk | contribs) (XML import of API documentation)
<sidebar>API Contents</sidebar> Divides the objects scale by a value
Class hierarchy
Panel
Position
ScaleDown
HANDLE Handle
FLOAT X
The local X scale to divide by
FLOAT Y
The local Y scale to divide by
FLOAT Z
The local Z scale to divide by
This divides the scale of the Handle object by an absolute value. Note the difference between scale and size. An objects scale is only equal to its size if it has no child objects to define its boundary.
If any of X, Y or Z is zero, that parameter is ignored.
  • Add to a calculation icon:
    ::Panel.Position.ScaleDown(handle, x, y, z)
