API Panel.Collision.TestTable
Revision as of 14:27, 9 August 2013 by JonnyW (talk | contribs) (XML import of API documentation)
<sidebar>API Contents</sidebar> Tests whether an object collides with the table top, returns Z distance to move to rest on the table
Class hierarchy
Panel
Collision
TestTable
HANDLE Pos
A component or position to focus the collision around
FLOAT
Returns Z distance to move to rest on the table
This calculates the distance between the lowest point on the objects bounding box and the table top, which is an infinite plane with Z = 0.
Distance to the table
The value returned is the distance to move in Z in order for the lowest point to lie on the table top. Note that this is not the same as the distance from the table which would be positive if the object was above the table, where as this would return the negative distance as the object would need to move down
  • Declare a variable 'result' of type FLOAT
  • Add to a calculation icon:
    result = ::Panel.Collision.TestTable(pos)
