Opening Flowcode
Revision as of 12:08, 18 July 2013 by ReeceL (talk | contribs)
<sidebar>Sidebar: Getting Started</sidebar>
When the Flowcode application starts, you have the option of loading an existing Flowcode file or creating a brand new flowchart.
Flowcode keeps a list of the most recently used files and these can be selected and opened by a double click. Select the 'Open an Existing Flowcode project...' option if the file you want to open is not on the recently used list.
You also have the option of opening a template to start a document with a pre-defined layout/set up for qucik and easy access to pre-built programs to expand upon.
You also have the option to launch the built-in Flowcode help files which consist of the base content of the Flowcode 6 wiki, there will also be links to the Flowcode 6 wiki itself.
