Exercise - Expanding a Program
Revision as of 08:12, 23 July 2013 by ReeceL (talk | contribs)
<sidebar>Sidebar: Taking Flowcode Further</sidebar> This exercise assumes you have created, tested and documented the program described in the exercise Documenting a Flowchart.
Because you have documented the flowchart properly, you can easily and accurately change the program as you know exactly how the program functions and what process it goes through.
Load the Flowcode flowchart
Enhancing programs
Now that you have a fully functioning program which is properly documented both by display names of icons and detailed comments, you can manipulate this program integrate it into another system, or expand the program further and turn it into your own expanded system, and even turn it into a full application.
You do not have to massively expand your program to make it more effective, sometimes a little change can make a big difference, adding as little as one component can change the program to be completely suitable for use elsewhere.
Expand your program
We are going to expand our program to function as a set of traffic lights, to do this we are going to add 2 more LEDs and add to our 'Decision' icon which responds to when the switch is on to activate the traffic lights accordingly.
Firs add two more LED components by either copying and paste the current component on the System Panel, or add two more by using the Components Toolbar
What Next?
Now you have effectively developed and expanded a program you can move on to other exercises and learn different areas, methods and techniques.
The next exercise available will show you how create an effective program using Component Macros and how to expand the program using Component Macros to increase efficiency. (See Exercise - Using Component Macros)
