API Sound.SetRate
Sets the current sample rate for the sound - this will stop the playing sound
HANDLE Sounds
- The handle of the sound object to modify
ULONG Rate
- The sample rate to set
The base sample is specified in creation through Sound.Create. This call stops the current playing sound and resets that rate. Subsequent sounds played through this handle will play at the given rate.
If the sound handle is currently playing samples, these will be cleared meaning noticeable glitches may occur. To avoid this, use the RateMul parameter in Sound.Queue or Sound.QueueEx to perform software conversion per wave, which will not glitch.
- Add to a calculation icon:
::Sound.SetRate(sounds, rate)
