API Component.Property.CopyValue
Revision as of 15:57, 16 January 2014 by JonnyW (talk | contribs) (XML import)
<sidebar>API Contents</sidebar> Copies a property value from one target to another
Class hierarchy
Component
Property
CopyValue
HANDLE Source
The source component to copy from
HANDLE Dest
The target component to copy to
STRING Property
The textual name of the property
STRING
The value copied to the Dest components Property.
This copies a components property value named Property from the Source component to the Dest. It is provided for convenience.
An equivalent call using SetValue from this to a dest component may be:
::Component.Property.SetValue(dest, "property", this::property)
And from any component to another:
value = ::Component.Property.GetValue(source, "property")
::Component.Property.SetValue(dest, "property", value)
  • Declare a variable 'result' of type STRING
  • Add to a calculation icon:
    result = ::Component.Property.CopyValue(source, dest, "property")
