API Panel.LinkBar.SetStartPos
Revision as of 15:57, 16 January 2014 by JonnyW (talk | contribs) (XML import)
<sidebar>API Contents</sidebar> Sets the position for the start point of the bar
Class hierarchy
Panel
LinkBar
SetStartPos
HANDLE LinkBar
The handle to the bar to adjust the position of
HANDLE Pos
The position to start the bar at
BOOL Track
Automatically update the bar to match changes in the position
This sets the start position of the link. A link is a bar that connects this start position to an end point.
If Track is true, the start of the link will always follow the current position. Note, that while the position will update, only visible objects will cause the screen to refresh, so for objects that are not visible (hidden components or position objects) call Update on a position change or intermittently to ensure the bar redraws correctly.
  • Add to a calculation icon:
    ::Panel.LinkBar.SetStartPos(linkbar, pos, false)
