API Panel.LinkBar.GetEndPos
Revision as of 15:57, 16 January 2014 by JonnyW (talk | contribs) (XML import)
<sidebar>API Contents</sidebar> Gets the position the bars end point is located at
Class hierarchy
Panel
LinkBar
GetEndPos
HANDLE LinkBar
The handle to the bar to read
BOOL Track
True to get a handle to the original position, false to make a copy
HANDLE
Returns the position the bars end point is located at
The end position is specified on creation of the link or in the SetEndPos call. This will extract the latest version of this, which may not contain the same values as the original if the position is being tracked.
  • Add to a calculation icon:
    result = ::Panel.LinkBar.GetEndPos(linkbar, true)
