API File.Buffer.Create
Revision as of 15:57, 16 January 2014 by JonnyW (talk | contribs) (XML import)
<sidebar>API Contents</sidebar> Creates the new file as a circular buffer
Class hierarchy
File
Buffer
Create
STRING Filename
The name of a new file to create
ULONG Bytes
The number of bytes to fix the buffer to
The default value for this parameter is: 0x10000
BOOL Write
Set to enable write access
BOOL Monitor
Set to enable monitoring of the file
HANDLE
  • Add to a calculation icon:
    result = ::File.Buffer.Create("filename", bytes, false, true)
