API File
Revision as of 15:57, 16 January 2014 by JonnyW (talk | contribs) (XML import)
<sidebar>API Contents</sidebar> File reading and writing operations
Sub-classes provided for this class
Buffer Reads writes and monitors circular buffers
NVM Reads from a file as though a block of NVM
Functions provided for this class
AbsPath Gets an absolute path from a relative filename
RelPath Gets an relative path from an absolute filename
CreateDir Creates a directory structure
GetType Finds the type of a file: 0=Unknown, 1=File, 2=Dir, 4=Disk
GetSize Gets the number of bytes in the file, by handle or name
Delete Deletes the file or directory structure
Create Creates the new file as a standard stream
Open Opens the existing file as a standard stream
ReadArray Reads an array from the file, returns elements read
WriteArray Writes an array to the file
SetPos Sets the position of the next read or write in the file
GetPos Gets the position of the next read or write in the file
Flush Writes all unwritten data to the file in one block
Constants provided for this class
Used by SetPos()
Type Name Value Description
LONG Seek_Begin 0 Position offset is an absolute value
LONG Seek_Curr 1 Position offset is relative to the current read/write position
LONG Seek_End 2 Position offset is relative to the end of the file
See also
