API Scope
<sidebar>API Contents</sidebar>
Data scope additions
Functions provided for this class
| AddGroup | Adds a group to the scope to which streams may be added |
| AddStream | Adds a stream to the given group suitable for inputs and operations |
| AddBuffer | Adds a fixed-view stream to the given group suitable for inputs and operations |
| Rename | Renames the given scope group, stream or buffer |
| AddPort | Adds an input to the stream from a port |
| AddAnalog | Adds an input to the stream from an analog channel |
| AddCustom | Adds an input to the stream from a custom injection |
| AddOp | Adds an operation to act on the inputs of the stream |
| SetBuffer | Sets the contents of a snapshot stream |
| SetCustom | Sets one of 32 custom analog values for the group |
| GetOutputBlock | Gets a block of the output stream with each input sample operated on, returns number of samples read |
| FindOutput | Searches back through the output history for a value, returns offset of found sample from TimeUS, 0 if not found |
Constants provided for this class
| Type | Name | Value | Description |
| LONG | Op_Bound | 1 | Bound the current value to the expected range of the input |
| LONG | Op_Scale | 2 | Divide the current value to the expected range of the input |
| LONG | Op_Xor | 3 | Exclusive-or with the provided integer argument |
| LONG | Op_AndNot | 4 | Clear the bits in the provided integer argument |
| LONG | Op_And | 5 | Isolate only the bits in the provided integer argument |
| LONG | Op_Orr | 6 | Set the bits in the provided integer argument |
| LONG | Op_Not | 7 | Invert (ones-compliment) the current input |
| LONG | Op_Add | 8 | Add the argument to the current input |
| LONG | Op_Sub | 9 | Subtract the argument from the current input |
| LONG | Op_Mul | 10 | Multiply the argument by the current input |
| LONG | Op_Div | 11 | Divide the current input by the argument |
| LONG | Op_Pow | 12 | Raise the input to the power of the argument |
| LONG | Op_Neg | 13 | Negate (twos compliment) the current input |
| LONG | Op_Recip | 14 | Perform the reciprocal on the current input |
| LONG | Op_Sqrt | 15 | Perform a square root on the current input |
| LONG | Op_Ln | 16 | Perform a natural logarithm on the current input |
| LONG | Op_Ln2 | 17 | Perform a base-2 logarithm on the current input |
| LONG | Op_Cos | 18 | Convert the input to its cosine value (input is in radians) |
| LONG | Op_Sin | 19 | Convert the input to its sine value (input is in radians) |
| LONG | Op_Tan | 20 | Convert the input to its tangent value (input is in radians) |
| LONG | Op_Int | 21 | Convert the input from a float to an integer (using the floor function) |
| LONG | Find_Lower | 1 | Match a search when output is lower than the target value |
| LONG | Find_Equal | 2 | Match a search when output is equal to the target value |
| LONG | Find_Higher | 4 | Match a search when output is greater than the target value |
| LONG | Find_LowHigh | 8 | Match a search when output goes lower to higher than the target |
| LONG | Find_HighLow | 16 | Match a search when output goes higher to lower than the target |
See also
