API Panel.PCloud.SetGridEx
Revision as of 14:27, 9 August 2013 by JonnyW (talk | contribs) (XML import of API documentation)
<sidebar>API Contents</sidebar> Sets the X,Y,Z point lists in a height-map grid
Class hierarchy
Panel
PCloud
SetGridEx
HANDLE PCloud
The handle to the cloud set the points of
FLOAT[] X
The array of X coordinates to use
FLOAT[] Y
The array of Y coordinates to use
FLOAT[] Z
The array of Z coordinates to use
ULONG OffsetInfo
The offset and step to increment each axis in
ULONG GridWidth
The width of the grid to calculate
ULONG Elements
The number of (X,Y,Z) points to set
  • Add to a calculation icon:
    ::Panel.PCloud.SetGridEx(pcloud, _arrayx, _arrayy, _arrayz, offsetinfo, gridwidth, elements)
