API Scope.GetOutputBlock
Revision as of 14:27, 9 August 2013 by JonnyW (talk | contribs) (XML import of API documentation)
<sidebar>API Contents</sidebar> Gets a block of the output stream with each input sample operated on, returns number of samples read
Class hierarchy
Scope
GetOutputBlock
HANDLE StreamH
The stream that is to be read
LONG TimeUS
The time offset to extract the history from, in microseconds
ULONG TimeStep
The step in microseconds between each sample extracted
ULONG Samples
The number of samples to extract - this will expand the array
FLOAT[] Buffer
The buffer to read the sample data into
ULONG
Returns the block of the output stream with each input sample operated on, returns number of samples read
  • Declare a variable 'result' of type ULONG
  • Add to a calculation icon:
    result = ::Scope.GetOutputBlock(streamh, timeus, timestep, samples, _arraybuffer)
