Component: MIDI (Comms: System)
| Author | Matrix Ltd. |
| Version | 1.3 (Release) |
| Category | Comms: System |
MIDI component
Low level routines for controlling or interacting with a standard MIDI interface.
SendMIDI
Sends a MIDI packet consisting of up to three bytes of information,
- BYTE Status
- MIDI Status Byte - Used for commands such as NoteOn, NoteOff etc.
- BYTE Data1
- MIDI Data Byte - Used as a parameter specific to the specified command
- BYTE Data2
SendPitchChange
Sends out a pitch change command on the specified channel.
- BYTE Channel
- Channel to send the pitch change to
- UINT Pitch_Change
- New pitch value to use, Default 0x2000
SendNoteOff
Sends a note off command using the channel, note and velocity specified.
- BYTE Channel
- BYTE Note
- BYTE Velocity
SendControl
Sends a control command using the channel, controller and value specified.
- BYTE Channel
- BYTE Controller
- BYTE Value
SendNoteOn
Sends a note on command using the channel, note and velocity specified.
- BYTE Channel
- BYTE Note
- BYTE Velocity
ReceiveMIDI
Waits for the time specified in the timeout parameter for an incoming MIDI message.
Returns 0 to indicate a timeout, otherwise returns the first value from the MIDI message.
- BYTE Timeout
SendPolyPressure
Sends a note press with an associated polyphonic pressure value.
- BYTE Channel
- BYTE Note
- BYTE Pressure
ReadData
- BYTE Idx
SendPatch
- BYTE Channel
- BYTE Instrument
SendChannelPressure
- BYTE Channel
- BYTE Pressure
Initialises the MIDI component and sets up the UART.
Simulation macro reference
This property is of type Fixed list of ints and can be referenced with the variable name CHANNEL.
TX
This property is of type Single digital pin and can be referenced with the variable name TX.
RX
This property is of type Single digital pin and can be referenced with the variable name RX.
Data Source
This property is of type Fixed list of ints and can be referenced with the variable name DataSource.
Simulation data source used to allow the component to connect to specific MIDI hardware or the the data injector components.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name Injector.
Lists all the current injector components available on the user's panel
