Component: Stepper Motor Template (Mechatronics)
| Author | Matrix Ltd |
| Version | 1.2 (Release) |
| Category | Mechatronics |
Enables the creation of a stepper motor component by specifying objects for its appearance. 'Attach to...' property should be exposed in any components buit from this - this sets a target object to be joined to the motor shaft. The target can then be rotated around the axis with a custom gear ration, or moved linearly according to the pitch of a given lead screw.
This component can be used as a base to create child components
The following components all inherit the traits of Stepper Motor Template:
IncrementStep
Move the motor forward by one step.
DecrementStep
Move the motor backwards by one step.
EnableMotor
Turn on the motor. This must be done before it will respond to any other macros.
DisableMotor
Turn off the motor. It will no longer respond to any other macros.
Simulation macro reference
SetTarget
Assign a panel object to be moved by the motor.
Once linked, the object will respond to the 'Motor Simulation' properties, and it
will be moved whenever the motor is stepped.
- HANDLE target
- An object to be moved by the motor.
Coil 1
This property is of type Single digital pin and can be referenced with the variable name Coil_1.
Chip pin to which the first motor coil is connected.
Coil 2
This property is of type Single digital pin and can be referenced with the variable name Coil_2.
Chip pin to which the second motor coil is connected.
Coil 3
This property is of type Single digital pin and can be referenced with the variable name Coil_3.
Chip pin to which the third motor coil is connected.
Coil 4
This property is of type Single digital pin and can be referenced with the variable name Coil_4.
Chip pin to which the fourth motor coil is connected.
Winding Type
This property is of type Fixed list of ints and can be referenced with the variable name Winding_Type.
The polarity settings of the motor windings.
Refer to the data-sheet for your chosen hardware to determine this value.
Step Type
This property is of type Fixed list of ints and can be referenced with the variable name Step_Type.
Trade accuracy against torque by changing the type of stepping.
Refer to the data-sheet for your chosen hardware to determine which modes your device supports.
Steps Per Revolution
This property is of type Signed integer and can be referenced with the variable name Steps_Per_Rev.
The number of steps it takes for the motor shaft to turn a full circle (360 degrees).
Rotating Part
This property is of type Panel object and can be referenced with the variable name moving_part.
Select a panel object here that will represent the moving part of the motor - for example, an
output shaft or actuator.
Rotation Centre
This property is of type Panel object and can be referenced with the variable name axis.
Select a panel object to be the centre of rotation of the 'Rotating Part'. If non is chosen, the
'Rotating Part' will revove around its own axes.
Rotate Around
This property is of type Fixed list of ints and can be referenced with the variable name rot_axis.
The axis of the 'Rotaion Centre' object around which the 'Rotating Part' will rotate.
Enable Sim
This property is of type True or false and can be referenced with the variable name coils_enable.
Turn coil simulation on and off.
Coil 1
This property is of type Panel object and can be referenced with the variable name coil1_object.
Choose a panel object to represent the first coil. The simulation will automatically change this
object's color to visualise when it is energised.
Coil 2
This property is of type Panel object and can be referenced with the variable name coil2_object.
Choose a panel object to represent the second coil. The simulation will automatically change this
Coil 3
This property is of type Panel object and can be referenced with the variable name coil3_object.
Choose a panel object to represent the third coil. The simulation will automatically change this
Coil 4
This property is of type Panel object and can be referenced with the variable name coil4_object.
Choose a panel object to represent the fourth coil. The simulation will automatically change this
Colour Non Active Coil
This property is of type Color picker and can be referenced with the variable name colour_non_act.
Make coil object this colour when they are NOT energised.
Colour Active Coil
This property is of type Color picker and can be referenced with the variable name colour_act.
Make the coil objects this colour when they ARE energised,.
Gear Ratio
This property is of type Floating point and can be referenced with the variable name gear_ratio.
Set a non-zero value here to make the target object rotate whenever the motor spins. The target
will revolve around the same axis as the motor's own 'Moving Part' (e.g. drive shaft).
A value of 1.00 make the target spin at the same speed as the motor. Choose other values
to set the ratio of a 'virtual gearbox' to change the speed of the target's movement.
X Linear Pitch
This property is of type Floating point and can be referenced with the variable name x_pitch.
Set this to a non-zero value to move the target object linearly along its X-Axis whenever the motor spins.
The value is the distance to move (world units) per complete rotation of the motor shaft - i.e. it
simulates a typical linear drive that uses a lead-screw, with the property value equal to the
screw pitch.
Y Linear Pitch
This property is of type Floating point and can be referenced with the variable name y_pitch.
Set this to a non-zero value to move the target object linearly along its Y-Axis whenever the motor spins.
screw pitch.
Z Linear Pitch
This property is of type Floating point and can be referenced with the variable name z_pitch.
Set this to a non-zero value to move the target object linearly along its Z-Axis whenever the motor spins.
screw pitch.
