Component: DALI Master (Comms: System)
Revision as of 15:45, 16 February 2017 by BenR (talk | contribs) (XML import BR)
Author MatrixTSL
Version 1.0 (Release)
Category Comms: System
Image DALI Master component
A serial based communications protocol designed for controlling lighting, specifically digitally controlled dimmable fluorescent ballasts. DALI requires the signals to be level shifted from VCC and GND to +9.5V - +25.5V and GND. The master component can addess up to 64 individual slaves & up to 16 groups.
DALI Master Example, reads the value of a keypad and sends out DALI commands based on the key pressed, 1 = switch on a slave's light, 2 = switch off a slave's light, 3 = read the slave's light level. DALI Master Example1 DALI Slave Example, listens for DALI messages and checks that the group is correct before attempting to process the request and if required reply to the master. DALI Slave Example1
ReceiveBackwardFrame
Attempts to receive an 8-bit reply
0 indicates timeout or no reply
This macro has no parameters
BYTE
TransmitForwardFrame
Send out a 16-bit frame consisting of the 8-bit address and data bytes.
After sending the controller will attempt to receive
If a reply is detected then the Return value will equal to the reply.
If no reply is detected then the Return value will be 0.
BYTE Address
Address byte
BYTE Data
Data Byte
BYTE
TransmitIndividualForwardFrame
Sends out an individual frame containing address and data.
After sending the controller will attempt to receive a reply.
BYTE Address
Individual Address 0-63
BYTE Type
0 = Data, 1 = Command
BYTE Data
BYTE
TransmitGroupForwardFrame
Sends out a group frame containing address and data.
BYTE Address
Group Address 0-15
BYTE Type
BYTE Data
BYTE
Configures the UART serial interface.
Simulation macro reference
TX Pin
This property is of type Single digital pin and can be referenced with the variable name TXPIN.
RX Pin
This property is of type Single digital pin and can be referenced with the variable name RXPIN.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name Injector.
