API Console.AddMemory
Revision as of 21:23, 11 May 2013 by Admin (talk | contribs) (XML import)
<sidebar>API contents</sidebar> Adds a window to the list of consoles available
===Class hierarchy===Console
AddMemory
STRING Name
The name to appear as the consoles title
ULONG Bytes
The number of bytes to add to the buffer
ULONG BpL
The number of bytes per line to display
The default value for this parameter is: 16
BYTE Init
The value to initialise each byte of memory to
BOOL UserWrite
Set true to allow amending of the data from the User
HANDLE
  • Add to a calculation icon:
    result = ::Console.AddMemory("name", bytes, bpl, init, false)
