Component: Switch (BL0145) (E-blocks 2)
| Version | 1.0 (Release) |
| Category | E-blocks 2 |
Switch (BL0145) component
A set of 8 push switches that can be connected to an E-blocks 2 upstream board via a port connector. Switches are wired in an active high configuration.
<span style="font-weight: normal;"><u><tt>ReadState</tt></u></span>
Read the state of the switch at the given index.
'''Parameters'''
- BYTE ''Index''
- The switch to read the status of.
'''Return value'''
- BOOL : Key state - true = on, false = off
<span style="font-weight: normal;"><u><tt>WaitUntilHigh</tt></u></span>
Pause the program until the switch at the given index is turned on.
'''Parameters'''
- BYTE ''Index''
- Index of the switch to wait for.
'''Return value'''
- ''This call does not return a value''
<span style="font-weight: normal;"><u><tt>ReadAll</tt></u></span>
Reads all of the switches at once, returning a byte containing one bit per
switch.
'''Parameters'''
- ''This macro has no parameters''
'''Return value'''
- BYTE : One bit per switch in the array.
<span style="font-weight: normal;"><u><tt>WaitUntilLow</tt></u></span>
'''Parameters'''
- BYTE ''Index''
'''Return value'''
Simulation macro reference
<span style="font-weight: normal;"><u>Input Mode</u></span>
This property is of type ''Fixed list of ints'' and can be referenced with the variable name ''port''.
Choose how your switches are connected.
PORT = Single port byte for all switches - pins are allocated in sequence from pin 0 - X
Custom = Individual pin by pin connections
<span style="font-weight: normal;"><u>Port</u></span>
This property is of type ''Digital port byte'' and can be referenced with the variable name ''PortByte''.
