Component: Modbus TCP Master (Comms: System)
| Author | Matrix Ltd. |
| Version | 2.0 (Release) |
| Category | Comms: System |
Modbus TCP Master component
Modbus component for talking to Modbus compatible hardware via Ethernet or WIFI. Ensure TCP/IP or WIFI component is intialised and connected to a network before calling the ModbusMasterTCP component macros.
ReadHoldingRegister
This command requests the analogue holding register values starting from the start RegAddress and going through to RegAddress plus RegCount.
Returns 0 for success, 1 for CRC fail and 255 for no reply.
- UINT SlaveID
- The ID of the MODBUS slave
- UINT RegAddress
- Address: 0=40001, 1=40002, ...
- UINT RegCount
- Number of consecutive registers to read, starting from RegAddress
ForceMultipleCoils
This command writes the contents of a series of discrete coils at the location starting at CoilAddress through to CoilAddress + CoilCount.
- BYTE SlaveID
- The ID of the MODBUS slave - Used for TCP to Serial forwarders
- UINT CoilAddress
- Coil Address: 0=Coil1, 1=Coil2, 2=Coil3, ...
- UINT CoilCount
- Number of consecutive coils to try and read
- BYTE CoilData
- An array of bytes each containing 8 1-bit coil values
ForceSingleCoil
This command writes the contents of a discrete coil at the location CoilAddress.
- BYTE SlaveID
- UINT CoilAddress
- BYTE CoilState
- 0=Off, 1=On
ReadCoilStatus
This command requests the ON/OFF status of discrete coils starting from the start CoilAddress and going through to CoilAddress plus CoilCount.
- UINT SlaveID
- UINT CoilAddress
- UINT CoilCount
GetResponseByte
Reads a byte from the last received response. The Index parametes specifies which byte to read back.
- BYTE Index
- 0=NumBytes, 1=SlaveAddress, 2=FunctionCode/ExceptionCode, .....
ReadInputStatus
This command requests the ON/OFF status of discrete inputs starting from the start DataAddress and going through to DataAddress plus DataCount.
- UINT SlaveID
- UINT DataAddress
- Input Address: 0=10001, 1=10002, 2=10003, ...
- UINT DataCount
- Number of consecutive inputs to read, starting from RegAddress
PresetSingleRegister
This command writes the contents of a analogue output holding registerl at the location RegAddress.
- UINT SlaveID
- UINT RegAddress
- UINT RegValue
- Value to send to the selected register
GetResponseInt
Reads a 16-bit value from the last received response.
The Index parametes specifies the byte index of the value to read back.
- BYTE Index
ReadInputRegister
This command requests the analogue input register values starting from the start RegAddress and going through to RegAddress plus RegCount.
- UINT SlaveID
- UINT RegAddress
- UINT RegCount
PresetMultipleRegisters
This command writes the contents of several analogue output holding registers starting at the location RegAddress through to location RegAddress + RegCount .
- UINT SlaveID
- UINT RegAddress
- UINT RegCount
- Number of consecutive registers to write, starting from RegAddress
- UINT RegValue
- Array of values to send to the registers
SetTCPAddress
Sets the address of the remote TCP Slave that we wish to control.
- <- STRING Address
- e.g. "192.168.1.1"
Simulation macro reference
TCP/IP Component
This property is of type Panel object and can be referenced with the variable name NetworkComms1::Component.
Property to point to the TCP/IP or WIFI component you want to use.
If unconnected then default to simulated TCP/IP network communications using the PC network adapter.
Status
This property is of type Line of text and can be referenced with the variable name NetworkComms1::Status.
TCP/IP Port
This property is of type Unsigned integer and can be referenced with the variable name Port.
Port used for network communications
Range: 0-65535
Receive Buffer Size
This property is of type Unsigned integer and can be referenced with the variable name ReceiveBufferSize.
