Component: LED (BL0167) (E-blocks 2)
| Version | 1.0 (Release) |
| Category | E-blocks 2 |
LED component to drive the E-blocks 2 BL0167 LED board. Provides eight individually addressable LEDs.
BarGraph
Turns on the first N elements of the array - for generating bar graph metes etc.
- BYTE Length
- How many items to light up. Range 0-8
LEDOn
Turns on the selected LED leaving the other LEDs as was.
- BYTE Index
- LED to switch on. Range: 0-7
AllOn
Switches On All LEDs.
LEDOff
Turns off the selected LED leaving the other LEDs as was.
- BYTE Index
- LED to switch off. Range: 0-7
PointGraph
Turns on the Indexed LED and turns all others off.
Does nothing if the index is out of range.
- BYTE Index
- The LED to light. Range: 0-7
WriteValue
Write a number which is presented on the LEDs in binary.
- BYTE Value
- Value to write to the LEDs. Range: 0-255
AllOff
Switches Off All LEDs.
Simulation macro reference
Output Mode
This property is of type Fixed list of ints and can be referenced with the variable name OutputMode.
Port
This property is of type Digital port byte and can be referenced with the variable name Port.
