Component: LCD (BL0169) (E-blocks 2)
Revision as of 14:51, 22 May 2018 by BenR (talk | contribs) (XML import - Pre 8.0 release)
Version 1.0 (Release)
Category E-blocks 2
Image LCD (BL0169) component
LCD component to drive the E-blocks 2 BL0169 LCD board. Provides a 4 x 20 character alphanumeric display.
Clear
This macro has no parameters
PrintString
<- STRING Text
Enter the text or variable to print to the LCD
This parameter may be returned back to the caller
PrintAscii
BYTE character
Holds an ascii value.
Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767
INT Number
RAMWrite
BYTE Index
Values 0 to 7
BYTE d0
BYTE d1
BYTE d2
BYTE d3
BYTE d4
BYTE d5
BYTE d6
BYTE d7
ClearLine
BYTE Line
The line to clear, zero being the first (top) line of the display
Cursor
BYTE x
Set the cursor position in the X plane, 0 is the left most cell
BYTE y
Set the cursor position in the Y plane, 0 is the top most cell
Command
BYTE instruction
Send a defined command to the LCD Screen. See datasheet for supported commands.
PrintFormattedNumber
Will allow you to print a number up to 32-bits with signed or unsigned formatting.
Signed = -2147483648 to 2147483647
Unsigned = 0 to 4294967295
ULONG Number
BOOL Format
0=Signed, 1=Unsigned
ScrollDisplay
BYTE Position
Holds the number of positions to shift the display
BYTE Direction
0 = left, 1 = right
RawSend
Sends data to the LCD display
BYTE data
The data byte to send to the LCD
BOOL type
A boolean to indicate command type: true to write data, false to write a command
RemapCharacter
Assigns a remap character allowing the PrintString function to automatically swap between pre-defined characters.
The characters can be custom (in the range 0-9) or can point to an existing character in the LCD character map.
BYTE RemapIdx
Remap Index, Range: 0 to (Remap Characters - 1)
BYTE SearchCharacter
Character to look for a replace
BYTE ReplacementCharacter
New character value to use in place of the search character.
Start
Startup routine required by the hardware device.
Automatically clears the display after initialising.
Simulation macro reference
Data 0 (11 / 7)
This property is of type Single digital pin and can be referenced with the variable name LCD1::Pin_Data_0.
Data pin 0 - Connects to Data 4 on the hardware in 4-bit mode or Data 0 in 8-bit mode
Data 1 (12 / 8)
This property is of type Single digital pin and can be referenced with the variable name LCD1::Pin_Data_1.
Data pin 1 - Connects to Data 5 on the hardware in 4-bit mode or Data 1 in 8-bit mode
Data 2 (13 / 9)
This property is of type Single digital pin and can be referenced with the variable name LCD1::Pin_Data_2.
Data pin 2 - Connects to Data 6 on the hardware in 4-bit mode or Data 2 in 8-bit mode
Data 3 (14 / 10)
This property is of type Single digital pin and can be referenced with the variable name LCD1::Pin_Data_3.
Data pin 3 - Connects to Data 7 on the hardware in 4-bit mode or Data 3 in 8-bit mode
Register Select (4)
This property is of type Single digital pin and can be referenced with the variable name LCD1::Pin_RS.
Register Select Pin - Informs the display if a command or data is about to be sent.
Enable (6)
This property is of type Single digital pin and can be referenced with the variable name LCD1::Pin_E.
Enable pin - Used to synchronise data writes to the display
