Component: Potentiometer (EBM002) (EBM Modules)
| Version | 1.1 (Release) |
| Category | EBM Modules |
Potentiometer (EBM002) component
This board consists of a standard shaft rotary potentiometer that provides a linear voltage output ranging between the microcontroller power rails. This can be connected to an Analogue to Digital input of the microcontroller in order to provide a control value.
ReadPotentiometer
Macro to read the potentiometer
Mode = 0 will return a byte
Mode = 1 will return an int
- BOOL Mode
- 0 = return BYTE, 1 = return INT
Simulation macro reference
Channel 1
This property is of type Single analog pin and can be referenced with the variable name CHANNEL1.
VRef voltage
This property is of type Signed integer and can be referenced with the variable name vrefvol.
+Vref voltage x 10mV
Default 500 = 5V
VRef option
This property is of type Fixed list of ints and can be referenced with the variable name vrefop.
Defines what is used as the ADC Vref source.
Conversion speed
This property is of type Fixed list of ints and can be referenced with the variable name convspd.
Clock setting to set how fast the ADC peripheral is driven.
Aquisition cycles
This property is of type Signed integer and can be referenced with the variable name actime.
