Component: Touch Pads (EBM013) (EBM Modules)
Revision as of 14:50, 22 May 2018 by BenR (talk | contribs) (XML import - Pre 8.0 release)
Version 1.0 (Release)
Category EBM Modules
Image Touch Pads (EBM013) component
This board provides two touch areas for use with capacitive sensing. Hence two digital touch switches can be implemented. This component directly interfaces with the EBM013 Sensors board.
GetTouchValue
Samples the touch sensor ADC value and returns it
Always samples both channels, but only returns the chosen channel
BOOL Switch
Select Switch. Switch 1 = 0, Switch 2 = 1
UINT
GetTouchPressed
Returns non-zero if touch detected
BOOL Switch
UINT OffValue
BYTE Threshold
Provide the threshold value for the pad to be considered touched
BOOL : Returns true if the operation is a success, else false
Simulation macro reference
Channel 1
This property is of type Single analog pin and can be referenced with the variable name CHANNEL1.
ADC Channel number
Channel 2
This property is of type Single analog pin and can be referenced with the variable name CHANNEL2.
On Value
This property is of type Unsigned integer and can be referenced with the variable name OnVal1.
Off Value
This property is of type Unsigned integer and can be referenced with the variable name OffVal1.
On Value
This property is of type Unsigned integer and can be referenced with the variable name OnVal2.
Off Value
This property is of type Unsigned integer and can be referenced with the variable name OffVal2.
