Component: SPI Slave (Comms: Interface)
| Author | Matrix Ltd |
| Version | 1.0 (Release) |
Low level routines for controlling or interacting with an SPI interface. SPI or Serial Peripheral Interface is a bus used for board level communications between devices. A target microcontroller will usually have at least one hardware SPI peripheral built in.
SendChar
General purpose SPI send byte macro
- BYTE Char
- Data byte to send
GetChar
General purpose SPI get byte macro
UnInitialise
Deactivates the SPI peripheral leaving the I/O pins in a state where they can be used for general purpose I/O.
Activates the SPI peripheral and claims control over the I/O pins.
Simulation macro reference
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi::CHANNEL.
SPI Channel selector
MOSI
This property is of type Single digital pin and can be referenced with the variable name cal_spi::MOSI.
MISO
This property is of type Single digital pin and can be referenced with the variable name cal_spi::MISO.
CLK
This property is of type Single digital pin and can be referenced with the variable name cal_spi::CLK.
Use Slave Select
This property is of type True or false and can be referenced with the variable name cal_spi::UseCS.
CS / SS
This property is of type Single digital pin and can be referenced with the variable name cal_spi::SS.
Chip Select / Slave Select Pin
Master Mode: General purpose output pin used to select the remote SPI device.
Slave Mode: Hardware chip select pin input used to select the SPI device.
Clock Phase
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi::CKE.
Clock Polarity
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi::CKP.
Sample Point
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi::SMP.
Data bit read sample point
Label used to identify the component on the panel.
This property is of type True or false and can be referenced with the variable name cal_spi::ScopeTraces.
This property is of type True or false and can be referenced with the variable name cal_spi::ConsoleData.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi::Injector.
