API Panel.Collision.GetSingleAxis
Revision as of 22:08, 11 May 2013 by Admin (talk | contribs) (XML import)
<sidebar>API contents</sidebar> Tests whether an object collides with a position
Class hierarchy
Panel
Collision
GetSingleAxis
HANDLE Pos
A component or position to focus the collision around
HANDLE Test
An object to test collisions with
FLOAT X
This parameter is returned back to the caller
Local or world-space X to return
FLOAT Y
Local or world-space Y to return
FLOAT Z
Local or world-space Z to return
HANDLE TargetSpace
The target space to calculate X,Y,Z in
BOOL
  • Add to a calculation icon:
    result = ::Panel.Collision.GetSingleAxis(pos, test, return_x, return_y, return_z, targetspace)
