Command Buffer Size
| Maximum number of bytes that can be stored in the outgoing command buffer.
Response Buffer Size
| Maximum number of bytes that can be stored in the incoming response buffer.
Script Count
| Controls how many AT scripts are stored into non-volatile memory
| UART Channel selector
Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels.
Hardware channels use the selected peripheral on-board the target microcontroller.
TX
| Pin to be used for Transmit data
RX
| Pin to be used for Receive data
Use Flow Control
Flow Control (Handshake) enable or disable.
On: Two I/O pins are used to control the flow of data in and out of the device.
Off: Flow control is disabled.
Baud Options
| Baud rate option selector
