Component: ADC (AD7680) (Analog Input)
Revision as of 19:53, 11 August 2021 by MartinW (talk | contribs)
Version 1.0 (Release)
Category Analog Input
Image ADC (AD7680) component
16-bit external ADC connected to the microcontroller using SPI.
Overview
The AD7680 is a 2.5V to 5.5V general purpose SPI compatible, successive approximation analogue to digital converter (ADC). The reference for the AD7680 is taken internally from VDD Pin reference from the datasheet:
This example reads the voltage on the AD7680 Vin and converts the ADC results into a voltage. For the result to be correct, you must change the Voltage variable to match the supply voltage.
FC6 Icon.png AD7680 Demo
Circuit Diagram
SampleADC
Reads the ADC and returns the reading as an unsigned 16-bit value.
Range: 0-65535 / 0=0V / 65535=VCC
This macro has no parameters
UINT
Initialise the SPI bus ready for communications,
Simulation macro reference
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::CHANNEL.
SPI Channel selector
Prescale
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::PR_SCALE.
Prescale option selector
MOSI
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::MOSI.
MISO
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::MISO.
CLK
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::CLK.
CS / SS
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::SS.
Chip Select / Slave Select Pin
Master Mode: General purpose output pin used to select the remote SPI device.
Slave Mode: Hardware chip select pin input used to select the SPI device.
Simulate Comms
This property is of type True or false and can be referenced with the variable name SimulateComms.
This property is of type True or false and can be referenced with the variable name cal_spi1::ConsoleData.
This property is of type True or false and can be referenced with the variable name cal_spi1::ScopeTraces.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::Injector.
