Bot test
| Author | Matrix Ltd. |
| Version | 2.0 (Release) |
| Category | Wireless |
GSM (EB066, Generic AT) component
Low level routines for controlling a standard AT GSM / GPRS interface Also available in the form of the EB066 GSM E-block.
GSM Example
The AT injector component allows us to simulate the response of the GSM module.
DialNumber
Performs a standard voice call by dialling the number specified.
Returns 0 for call in progress and 255 for no response.
- <- STRING Number
GetTextString
Collects the text message data from an incoming text message.
- BYTE NumBytes
SendString
Sends a string to the GSM module.
- <- STRING Text
SendScript
Send an AT command script.
Returns 0 for fail, 1 for success and 255 for unrecognised script idx.
- BYTE idx
AnswerIncomingCall
Answers the phone for an incoming type call.
Returns 0 for success and 255 for failure.
SendCommand
Sends a command string to the GSM module.
0 = Command sent ok, 255 = No Reply
- <- STRING Command
- BYTE SendCR
GetTextNumber
Collects the sender's phone number from an incoming text message.
- BYTE NumBytes
HangUpCall
Ends a voice based call.
ReadString
Copies the data from the data string array to a local string variable
- BYTE NumBytes
SendTextMessage
Sends the text message data specified to the number specified using the SMS protocol.
- <- STRING Number
- <- STRING Message
StringReceive
Attempts to receive a string from the GSM modem.
DeleteAllMessages
Removes all pending text messages from the GSM module.
Returns 0 for success and 255 for fail.
CheckNetworkStatus
Returns the state of the GSM network.
0 = Not connected, 1 = connected, 255 = no reply from GSM.
CheckForIncoming
Checks to see if any incoming phone call or SMS message.
0 = Nothing, 1 = Text Received, 2 = Phone Ringing
Sets up the GSM module.
Returns 0 for OK, 255 for no reply and 254 for command fail.
Simulation macro reference
Expect Echo
This property is of type True or false and can be referenced with the variable name expect_echo.
Sets if we expect an echo of any data we send out to the GSM modem.
Most AT type modems (e.g. GSM modules) will automatically echo back incoming data.
String Array Size
This property is of type Signed integer and can be referenced with the variable name string_size.
Amount of RAM memory to dedicate to receiving responces from the GSM
Message Array Size
This property is of type Signed integer and can be referenced with the variable name message_size.
Amount of RAM memory to dedicate to storing the last SMS message received by the GSM.
Script Count
This property is of type Fixed list of ints and can be referenced with the variable name script_count.
Maximum number of scripts to store in the device's ROM
Script1
This property is of type Multiple lines of text and can be referenced with the variable name script1.
ASCII based AT command data stored in ROM and used when sending script 1
This property is of type Fixed list of ints and can be referenced with the variable name cal_uart::CHANNEL.
UART Channel selector
Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels.
Hardware channels use the selected peripheral on-board the target microcontroller.
TX
This property is of type Single digital pin and can be referenced with the variable name cal_uart::TX.
RX
This property is of type Single digital pin and can be referenced with the variable name cal_uart::RX.
Use Flow Control
This property is of type Fixed list of ints and can be referenced with the variable name cal_uart::FLOWEN.
Flow Control (Handshake) enable or disable.
On: Two I/O pins are used to control the flow of data in and out of the device.
Off: Flow control is disabled.
Baud Options
This property is of type Fixed list of ints and can be referenced with the variable name cal_uart::BAUD_LIST.
This property is of type Signed integer and can be referenced with the variable name cal_uart::BAUD.
Textual label shown on the component I/O flasher
This property is of type True or false and can be referenced with the variable name cal_uart::ScopeTraces.
Selects if the scope traces are automatically added to the data recorder window or not.
Simulation - draws an approximation of the UART data onto the scope trace.
ICT - sets up the scope trace for incoming data and adds UART packet decoding at the correct BAUD.
This property is of type True or false and can be referenced with the variable name cal_uart::ConsoleData.
Console Columns
This property is of type Unsigned integer and can be referenced with the variable name cal_uart::ConsoleColumns.
Data Source
This property is of type Fixed list of ints and can be referenced with the variable name cal_uart::DataSource.
Simulation data source used to allow the component to connect to various remote devices
Nothing - Simulation data is ignored
COM port - Routes the communication data to and from a physical or virtual COM port
Injector - Routes the communication data via a data injector component on the Panel.
