Component: Panel Console Viewer (Runtime Tools)
Revision as of 13:49, 7 July 2021 by BenR (talk | contribs) (XML import)
Version 1.1 (Release)
Category Runtime Tools
Image Panel Console Viewer component
An easy way to display the data from a console on the panel. Links to a component that generates console data.
This component does not contain any downloadable macros
Simulation macro reference
Connect To
This property is of type Panel object and can be referenced with the variable name ConnectTo.
Width
This property is of type Floating point and can be referenced with the variable name Width.
Width of the console ripper component.
Number of lines
This property is of type Unsigned integer and can be referenced with the variable name NumLines.
Clear Old Data
This property is of type True or false and can be referenced with the variable name ClearOldData.
Removes old data from the console viewer when starting simulation if active.
