Component: IoT Made Easy (Comms: IoT/Cloud)
| Version | 1.0 (Release) |
| Category | Comms: IoT/Cloud |
A component designed to simplify MQTT comms allowing for multiple data streams to be dealt with in a simple manner. Deals with translating values to and from the broker from topic strings into message IDs and numeric values. Works with lots of different MQTT brokers.
ErrorAsString
- BYTE Error
PublishString
Publishes data to the selected topic ID using a data string.
Returns none zero if successful
- BYTE TopicID
- The topic ID to publish data to
- <- STRING Data
- Data string to publish
GetTopicID
Compares the topic ID of the last received message with enabled IDs.
Returns the topic ID received.
Connect
Connect to the MQTT Server.
Returns the connected state.
0 if not connected, 1 if successful connection, or already connected.
GetPayloadInteger
Get the Payload of the last received (Read) packet as a signed long value
LastError
Returns the last error
Read
Read incoming data.
Returns non-zero if packet received.
Use GetTopicID and GetPayloadXXX to read the contents.
Disconnect
Disconnects from the MQTT server and the network
PublishFloat
Publishes data to the selected topic ID using a floating point value.
- BYTE TopicID
- FLOAT Data
- Data to publish
Ping
Ping packet is sent to the server and checks for a reply.
If nothing is sent or received within the keep alive period then a ping is required to keep the connection to the server active.
Returns non-zero value if successful
PublishInteger
Publishes data to the selected topic ID using a signed long integer value.
- BYTE TopicID
- LONG Data
- Data to publish
GetPayloadFloat
Get the Payload of the last received (Read) packet as a floating point value
GetPayloadString
Get the Payload of the last received (Read) packet.
Returns the number of bytes for the Payload
- <- STRING Payload
- BYTE Size
- Byte count the Payload buffer
Starts up the MQTT component - call this after initialising the NetworkComms component.
Simulation macro reference
Host
This property is of type Line of text and can be referenced with the variable name MQTT_Client1::HOST.
Address of MQTT Broker
Port
This property is of type Unsigned integer and can be referenced with the variable name MQTT_Client1::PORT.
Port used by MQTT Broker
Client identifier
This property is of type Line of text and can be referenced with the variable name MQTT_Client1::CLIENT.
Client identifier (Maximum length 20 characters)
Network Timeout
This property is of type Unsigned integer and can be referenced with the variable name MQTT_Client1::TIMEOUT.
Maximum time in mS to wait for network responses
Keep Alive
This property is of type Unsigned integer and can be referenced with the variable name MQTT_Client1::KEEP_ALIVE.
The Keep Alive is the maximum time interval that is permitted to elapse
between the point at which the Client finishes transmitting one Control Packet
and the point it starts sending the next, measured in seconds.
Network Component
This property is of type Panel object and can be referenced with the variable name MQTT_Client1::NETWORK_COMPONENT.
Pointer to the network communications component providing TCP simulation and abstraction for embedded
TCP modules.
Authentication
This property is of type Fixed list of ints and can be referenced with the variable name MQTT_Client1::AUTHENTICATION.
Number of topics
This property is of type Fixed list of ints and can be referenced with the variable name NumTopics.
Sets the number of data topics that can be sent or received
Topic String
This property is of type Line of text and can be referenced with the variable name Topic0.
Topic Type
This property is of type Fixed list of ints and can be referenced with the variable name TopicType0.
Topic String
This property is of type Line of text and can be referenced with the variable name Topic1.
Topic Type
This property is of type Fixed list of ints and can be referenced with the variable name TopicType1.
Topic String
This property is of type Line of text and can be referenced with the variable name Topic2.
Topic Type
This property is of type Fixed list of ints and can be referenced with the variable name TopicType2.
Topic String
This property is of type Line of text and can be referenced with the variable name Topic3.
Topic Type
This property is of type Fixed list of ints and can be referenced with the variable name TopicType3.
Topic String
This property is of type Line of text and can be referenced with the variable name Topic4.
Topic Type
This property is of type Fixed list of ints and can be referenced with the variable name TopicType4.
Topic String
This property is of type Line of text and can be referenced with the variable name Topic5.
Topic Type
This property is of type Fixed list of ints and can be referenced with the variable name TopicType5.
Topic String
This property is of type Line of text and can be referenced with the variable name Topic6.
Topic Type
This property is of type Fixed list of ints and can be referenced with the variable name TopicType6.
Topic String
This property is of type Line of text and can be referenced with the variable name Topic7.
Topic Type
This property is of type Fixed list of ints and can be referenced with the variable name TopicType7.
Topic String
This property is of type Line of text and can be referenced with the variable name Topic8.
Topic Type
This property is of type Fixed list of ints and can be referenced with the variable name TopicType8.
Topic String
This property is of type Line of text and can be referenced with the variable name Topic9.
Topic Type
This property is of type Fixed list of ints and can be referenced with the variable name TopicType9.
Topic String
This property is of type Line of text and can be referenced with the variable name Topic10.
Topic Type
This property is of type Fixed list of ints and can be referenced with the variable name TopicType10.
Topic String
This property is of type Line of text and can be referenced with the variable name Topic11.
Topic Type
This property is of type Fixed list of ints and can be referenced with the variable name TopicType11.
