Component: Touch Slider (EBM014) (EBM Modules)
| Version | 1.0 (Release) |
| Category | EBM Modules |
This board provides two touch slide areas for use with capacitive sensing. Therefore, two digital touch sliders can be implemented. This component directly interfaces with the EBM014 Sensors board.
Sample program using the EBM014 - Touch Slider sensor.
Reads both sensors and displays the value on the LCD and LEDs
GetTouchValue
Samples the touch sensor ADC value and returns it
Always samples both channels, but only returns the chosen channel
- BOOL Switch
- 0 = S1, 1 = S2
Simulation macro reference
Channel 1
This property is of type Single analog pin and can be referenced with the variable name CHANNEL1.
ADC Channel number
Channel 2
This property is of type Single analog pin and can be referenced with the variable name CHANNEL2.
Minimum S1
This property is of type Unsigned integer and can be referenced with the variable name MinimumS1.
Maximum S1
This property is of type Unsigned integer and can be referenced with the variable name MaximumS1.
Minimum S2
This property is of type Unsigned integer and can be referenced with the variable name MinimumS2.
Maximum S2
This property is of type Unsigned integer and can be referenced with the variable name MaximumS2.
