Component: Barometer (DPS310) (Environmental)
Revision as of 13:40, 7 July 2021 by BenR (talk | contribs) (XML import)
Version 1.0 (Release)
Category Environmental
Image Barometer (DPS310) component
A barometric air pressure sensor with high accuracy and low current consumption. Capable of sensing air pressure and temperature. Based on an I2C bus connection.
ReadTemperature
Reads the temperature measurement from the last SampleSensor macro
This macro has no parameters
FLOAT
ConfigurePressure
Configures the pressure sensor sample rate and over sampling count
BYTE Rate
Range: 0-7, 0=1Hz, 1=2Hz, 2=4Hz etc
BYTE Oversample
Range: 0-7, 0=1Samples, 1=2Samples, 2=4Samples etc
ConfigureTemperature
Configures the temperature sensor sample rate and over sampling count
BYTE Rate
BYTE Oversample
ReadPressure
Reads the pressure measurement from the last SampleSensor macro
FLOAT
SetMode
Sets the operational mode of the sensor to be continous or one shot
BYTE Mode
ReadAltitude
Reads the pressure measurement from the last SampleSensor macro and converts the pressure reading into an altitude reading.
FLOAT
SampleSensor
Checks to see if new data is available for temperature or pressure and collects it.
Returns 0 if no new data is available
Returns 1 for pressure, 2 for temperature and 3 for both.
BYTE
Starts up the I2C ready to communicate with the sensor.
Sets the selected rates and operational mode.
Returns 1 if the sensor has been found and initialised.
BOOL : Returns true if the operation is a success, else false
Simulation macro reference
Device Address
This property is of type Fixed list of ints and can be referenced with the variable name DeviceAddress.
Measurement Rate
This property is of type Fixed list of ints and can be referenced with the variable name MeasurementRate.
Oversample Rate
This property is of type Fixed list of ints and can be referenced with the variable name OversampleRate.
Operational Mode
This property is of type Fixed list of ints and can be referenced with the variable name OpMode.
This property is of type Fixed list of ints and can be referenced with the variable name cal_i2c1::CHANNEL.
Channel selection
Baud Select
This property is of type Fixed list of ints and can be referenced with the variable name cal_i2c1::BAUD_LIST.
This property is of type Signed integer and can be referenced with the variable name cal_i2c1::BAUD.
Baud rate to be used
SDA
This property is of type Single digital pin and can be referenced with the variable name cal_i2c1::SDA.
SCL
This property is of type Single digital pin and can be referenced with the variable name cal_i2c1::SCL.
Stop Delay
This property is of type True or false and can be referenced with the variable name cal_i2c1::StopDel.
On older microcontroller devices there is a potential for the I2C hardware channel to lock up if there is not
a 10ms delay between an I2C stop event and the next I2C start event.
Most modern microcontrollers will not have a problem so this property can be disabled to speed up the
I2C communications.
Simulate Comms
This property is of type True or false and can be referenced with the variable name SimComms.
No: Provides simulation using the panel component sliders.
Yes: Communicates via an API Slave device to real world hardware, shows the results using the panel component sliders.
This property is of type True or false and can be referenced with the variable name cal_i2c1::ScopeTraces.
Selects if the component pin connections are automatically generated on the data recorder window or not.
Yes: Automatically add the component pins to a group on the data recorder which will reflect the sim data during simultion.
No: Do not show the pin signals on the data recorder window.
This property is of type True or false and can be referenced with the variable name cal_i2c1::ConsoleData.
API
This property is of type Fixed list of ints and can be referenced with the variable name cal_i2c1::Injector.
Specifies the API component on the panel to interact with to provide comms simulation.
