Component: USB MIDI (Comms: USB)
Revision as of 15:47, 20 July 2016 by BenR (talk | contribs) (XML import)
Author Matrix Ltd.
Version 1.3 (Release)
Category Comms: USB
Image USB MIDI component
Component to create and communicate using a standard MIDI connection. Compatible with simulation and USB enabled microcontroller devices. Currently only compatible with the 16-bit PIC range of devices.
SendMIDI
Sends a MIDI packet consisting of up to three bytes of information,
BYTE Status
MIDI Status Byte - Used for commands such as NoteOn, NoteOff etc.
BYTE Data1
MIDI Data Byte - Used as a parameter specific to the specified command
BYTE Data2
SendPitchChange
Sends out a pitch change command on the specified channel.
BYTE Channel
Channel to send the pitch change to
UINT Pitch_Change
New pitch value to use, Default 0x2000
SendNoteOff
Sends a note off command using the channel, note and velocity specified.
BYTE Channel
BYTE Note
BYTE Velocity
SendControl
Sends a control command using the channel, controller and value specified.
BYTE Channel
BYTE Controller
BYTE Value
SendNoteOn
Sends a note on command using the channel, note and velocity specified.
BYTE Channel
BYTE Note
BYTE Velocity
ReceiveMIDI
Waits for the time specified in the timeout parameter for an incoming MIDI message.
Returns 0 to indicate a timeout, otherwise returns the first value from the MIDI message.
BYTE Timeout
BYTE
SendPolyPressure
Sends a note press with an associated polyphonic pressure value.
BYTE Channel
BYTE Note
BYTE Pressure
ReadData
Reads a byte from the last received MIDI message
BYTE Idx
Byte to read 0-3
BYTE
SendPatch
BYTE Channel
BYTE Instrument
SendChannelPressure
BYTE Channel
BYTE Pressure
Starts up the USB communications and attempts to enumerate.
Returns 0 for a successful startup or 255 for a enumeration timeout.
This macro has no parameters
BYTE
Simulation macro reference
Vendor ID
This property is of type Signed integer and can be referenced with the variable name vendor_ID.
USB VID
Product ID
This property is of type Signed integer and can be referenced with the variable name product_ID.
USB PID
Device Name
This property is of type Line of text and can be referenced with the variable name dev_name.
USB Device Name
Manufacturer
This property is of type Line of text and can be referenced with the variable name dev_manufacturer.
USB Manufacturer
Major Version
This property is of type Signed integer and can be referenced with the variable name major_version.
USB Major Version Number
Minor Version
This property is of type Signed integer and can be referenced with the variable name minor_version.
USB Minor Version Number
Enumeration Timeout
This property is of type True or false and can be referenced with the variable name enumeration_tout.
Specifies if the enumeration (Initialise function) can timeout if taking too long.
Text displayed on the I/O flasher comms component.
Data Source
This property is of type Fixed list of ints and can be referenced with the variable name DataSource.
Simulation data source used to allow the component to connect to specific MIDI hardware or the the data injector components.
MIDI Port
This property is of type Fixed list of ints and can be referenced with the variable name Midi_Port.
