Component: Linear Actuator (Mechatronics)
Author | Matrix TSL |
Version | 1.0 (Release) |
Category | Mechatronics |
Linear Actuator component
Creates a linear actuator that can be used with the various motor components via a coupling or gearbox.
CheckLimits
Checks to see if either limit switch is active.
Returns 1 if min switch is active, 2 if max switch is active, 3 if both switches are active
else returns 0.
Simulation macro reference
Rotate
Simulation Rotate function to allow accurate rotation during simulation.
Automatically called by any attached coupling or gearbox component.
- FLOAT Angle
- Amount to rotate the shaft input in degrees
Translation Per Rev
This property is of type Floating point and can be referenced with the variable name Ratio.
Sets the amount of translation for each revolution of the input shaft.
M4 = 0.7mm
M5 = 0.8mm
M6 = 1.0mm
M8 = 1.25mm
M10 = 1.5mm
Travel
This property is of type Floating point and can be referenced with the variable name Length.
Amount of travel in the linear actuator before hitting the end stops
Revolutions
This property is of type Floating point and can be referenced with the variable name NumRevs.
Number of revolutions the actuator can travel
Colour
This property is of type Color picker and can be referenced with the variable name Colour.
Sets the colour of the actuator and end stops
Output
This property is of type Panel object and can be referenced with the variable name Output.
Output connection for example an end tool or another linear slide and motor group.
Output Offset X
This property is of type Floating point and can be referenced with the variable name OutputOffsetX.
Distance along the X axis from the center of the coupling to the center of the output object.
Output Offset Y
This property is of type Floating point and can be referenced with the variable name OutputOffsetY.
Output Offset Z
This property is of type Floating point and can be referenced with the variable name OutputOffsetZ.
Distance along the shaft from the center of the coupling to the center of the output object.
Limit Type
This property is of type Fixed list of ints and can be referenced with the variable name LimitType.
Controls if limit switches are available on the linear actuator.
Switch Polarity
This property is of type Fixed list of ints and can be referenced with the variable name SwitchPolarity.
Sets the active polarity of the input switches.
Active low are often used to help reduce noise on the switch inputs.
Min Switch Pin
This property is of type Single digital pin and can be referenced with the variable name MinPin.
Pin connection used for the minimum limit switch
Max Switch Pin
This property is of type Single digital pin and can be referenced with the variable name MaxPin.
Pin connection used for the maximum limit switch
