Author
Matrix TSL
Version
1.0
Category
General Output
PWM 16CH 12Bit (PCA9685) component
The PCA9685 is an I²C-bus controlled 16-channel LED controller optimized for Red/Green/Blue/Amber (RGBA) color backlighting or Servo motor applications. Each output has its own 12-bit resolution (4096 steps) fixed frequency individual PWM controller that operates at a programmable frequency from a typical of 24 Hz to 1526 Hz. All outputs are set to the same PWM frequency. Up to 64 devices can be chained together on a single I²C-bus to provide up to 1024 individual PWM outputs.
Reset
Sends a reset command to the PCA9685 chip over I2C
SetPWMFrequency
Sets the PWM frequency for the entire chip, up to approx 1.6 KHz
[[File:]] -
Frequency
Floating point frequency that we will attempt to match
SetOutputMode
Sets the output mode of the PCA9685 to either open drain or push pull. Warning: LEDs with integrated zener diodes should only be driven in open drain mode.
[[File:]] -
Mode
0=OpenDrain, 1=Push/Pull
Sleep
Puts the module into Sleep mode
SetExternalClock
Sets EXTCLK pin to use the external clock
- BYTE
Prescale
External Clock Prescaler - Range: 3-255
SetAddress
Allows a different I2C address to be specified allowing one component to control multiple PCA9685 modules.
- BYTE
Address
Range: 0x40 - 0x7F
SetClockFrequency
Sets the current clock frequency, used for things like calculating the PWM frequency and Microsecond duty.
- ULONG
Clock
GetClockFrequency
Returns the current clock frequency
- ULONG
WriteMicroseconds
Sets the PWM output of one of the PCA9685 pins based on the input microseconds, output is not precise
- BYTE
Output
One of the PWM output pins - Range: 0 to 15
- UINT
Microseconds
The number of Microseconds to turn the PWM output ON
SetPWM
- BYTE
Output
- UINT
On
At what point in the 4096-part cycle to turn the PWM output ON
- UINT
Off
At what point in the 4096-part cycle to turn the PWM output OFF
Sets up the I2C ready for communications to begin
WakeUp
Wakes the module from Sleep mode
SetPin
Sets pin without having to deal with on/off tick placement and properly handles a zero value as completely off and 4095 as completely on.
- BYTE
Output
- UINT
Duty
The number of ticks out of 4096 to be active
[[File:]] -
Invert
0=Normal, 1=Inverted
DrawRectangle2D
Draws a basic 2D rectangle onto the LEDs
- BYTE
X1
- BYTE
Y1
- BYTE
X2
- BYTE
Y2
- BYTE
DrawStyle
Sets the draw style - 0=Soild, 1=Edge, 2=Corners
- BYTE
R
- BYTE
G
- BYTE
B
ShiftLEDs2D
Shifts the contents of the display by the number of vertices specified ***Please Note that Wrap mode is currently unavailable***
[[File:]] -
X
Number of pixels to shift the display -1 to 1 / 0 = No Shift
[[File:]] -
Y
- BYTE
DataMode
0=ResetToZero, 1=WrapAroundDisplay, 2=Smear
GetLEDIndex3D
Gets the index of a single LED in RAM as a 3D array.
- UINT
X
LED Column to change the colour / Range: 0 to (LED Column - 1)
- UINT
Y
LED Row to change the colour / Range: 0 to (LED Row - 1)
- UINT
Z
LED Layer to change the colour / Range: 0 to (LED Layer - 1)
- UINT
DrawCuboid3D
Draws a basic 3D cuboid onto the LEDs
- BYTE
X1
Start X pixel coordinate
- BYTE
Y1
Start Y pixel coordinate
- BYTE
Z1
Start Z pixel coordinate
- BYTE
X2
End X pixel coordinate
- BYTE
Y2
End Y pixel coordinate
- BYTE
Z2
End Z pixel coordinate
- BYTE
DrawStyle
- BYTE
R
Red Colour Channel
- BYTE
G
Green Colour Channel
- BYTE
B
White Colour Channel
Inisialises the RGB colour RAM to 0,0,0 = LED Off and clocks out the data to initialise all the LED ICs in the chain.
ShiftLEDs3D
[[File:]] -
X
[[File:]] -
Y
[[File:]] -
Z
- BYTE
DataMode
Sets up the data memory and draws the simulated LED cube on the panel.
Address
Module I2C Address. This setting can be overridden using the SetAddress component macro.
Output Mode
Sets the output mode of the PCA9685 to either open drain or push pull. Warning: LEDs with integrated zener diodes should only be driven in open drain mode. Can be overridden using the SetOutputMode component macro.
Clock Type
Configures the input clock source to the module.
Clock Frequency
Frequency of the module. Internal oscillator defaults to 250000000 or 25MHz but can actually be anywhere from 23 to 27MHz. External clock frequency can be specified here up to a max value of 50000000 or 50MHz. This setting can be overridden using the SetClockFrequency component macro.
Prescaler
External Clock Prescaler Range: 3 to 255
Target PWM Frequency
The ideal PWM frequency we would like to generate on the output pins. Servo motors require an output frequency around 50Hz. LEDs require a mugh higher output frequency to avoid visible flicker.
Actual PWM Frequency
The calculated actual PWM frequency available using the Clock Frequency and Prescaler
PWM Resolution
Number of microseconds the PWM output can resolve to
Channel selection
Baud Select
Baud rate to be used
SDA
SCL
Stop Delay
API
Specifies the API component on the panel to interact with to provide comms simulation.
Simulations
Simulate Comms
