Component: Piezo Sounder (Audio Output)
Revision as of 21:07, 16 November 2021 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix TSL |- | width="20%" style="color:gray;" | Version | 1.0 |- | width="20%" style="color:gray...")
Category Audio Output
Piezo Sounder component
Drives a simple variable frequency piezo sounder in hardware and simulates the sound in simulation. To actually drive a piezo you may have to amplify the signal from the microcontroller using a transistor or MOSFET.
Here is a simple example that will create a siren effect using a piezo sounder. FC6 Icon.png Piezo Siren Depending on your Piezo Sounder you may need to amplify the signal from the microcontroller using a NPN transistor or N channel FET.
Fc9-comp-macro.png BuzzerBeep
Switches the buzzer on and off automatically to allow for a series of beeps
Fc9-u16-icon.png - UINT OnTime
Length of time in ms the buzzer will remain on
Fc9-u16-icon.png - UINT OffTime
Length of time in ms the buzzer will remain off
Fc9-u8-icon.png - BYTE NumberLoops
Number of times to repeat the sequence. Range 1-255
Fc9-u16-icon.png - UINT Frequency
frequency in hz to output to the Piezo sounder
Fc9-comp-macro.png BuzzerOnDelay
Switch the Buzzer on for a fixed amount of time
Fc9-u16-icon.png - UINT Time
Time in milliseconds to keep the buzzer on
Frequency to output in Hz
Fc9-comp-macro.png SetAddress
Allows a different I2C address to be specified allowing one component to control multiple PCA9685 modules.
Range: 0x40 - 0x7F
Fc9-comp-macro.png SetClockFrequency
Sets the current clock frequency, used for things like calculating the PWM frequency and Microsecond duty.
Fc9-u32-icon.png - ULONG Clock
Fc9-comp-macro.png GetClockFrequency
Returns the current clock frequency
Fc9-u32-icon.png - ULONG Return
Fc9-comp-macro.png WriteMicroseconds
Sets the PWM output of one of the PCA9685 pins based on the input microseconds, output is not precise
Fc9-u8-icon.png - BYTE Output
One of the PWM output pins - Range: 0 to 15
Fc9-u16-icon.png - UINT Microseconds
The number of Microseconds to turn the PWM output ON
Fc9-comp-macro.png SetPWM
At what point in the 4096-part cycle to turn the PWM output ON
At what point in the 4096-part cycle to turn the PWM output OFF
Fc9-comp-macro.png Initialise
Sets up the I2C ready for communications to begin
Fc9-comp-macro.png WakeUp
Wakes the module from Sleep mode
Fc9-comp-macro.png SetPin
Sets pin without having to deal with on/off tick placement and properly handles a zero value as completely off and 4095 as completely on.
Fc9-u16-icon.png - UINT Duty
The number of ticks out of 4096 to be active
[[File:]] - Invert
0=Normal, 1=Inverted
Fc9-comp-macro.png DrawRectangle2D
Draws a basic 2D rectangle onto the LEDs
Fc9-u8-icon.png - BYTE X1
Fc9-u8-icon.png - BYTE Y1
Fc9-u8-icon.png - BYTE X2
Fc9-u8-icon.png - BYTE Y2
Fc9-u8-icon.png - BYTE DrawStyle
Sets the draw style - 0=Soild, 1=Edge, 2=Corners
Fc9-u8-icon.png - BYTE R
Fc9-u8-icon.png - BYTE G
Fc9-u8-icon.png - BYTE B
Fc9-comp-macro.png ShiftLEDs2D
Shifts the contents of the display by the number of vertices specified ***Please Note that Wrap mode is currently unavailable***
[[File:]] - X
Number of pixels to shift the display -1 to 1 / 0 = No Shift
[[File:]] - Y
Fc9-u8-icon.png - BYTE DataMode
0=ResetToZero, 1=WrapAroundDisplay, 2=Smear
Fc9-comp-macro.png GetLEDIndex3D
Gets the index of a single LED in RAM as a 3D array.
Fc9-u16-icon.png - UINT X
LED Column to change the colour / Range: 0 to (LED Column - 1)
Fc9-u16-icon.png - UINT Y
LED Row to change the colour / Range: 0 to (LED Row - 1)
Fc9-u16-icon.png - UINT Z
LED Layer to change the colour / Range: 0 to (LED Layer - 1)
Fc9-comp-macro.png DrawCuboid3D
Draws a basic 3D cuboid onto the LEDs
Start X pixel coordinate
Start Y pixel coordinate
Fc9-u8-icon.png - BYTE Z1
Start Z pixel coordinate
End X pixel coordinate
End Y pixel coordinate
Fc9-u8-icon.png - BYTE Z2
End Z pixel coordinate
Red Colour Channel
Green Colour Channel
White Colour Channel
Inisialises the RGB colour RAM to 0,0,0 = LED Off and clocks out the data to initialise all the LED ICs in the chain.
Fc9-comp-macro.png ShiftLEDs3D
[[File:]] - X
[[File:]] - Y
[[File:]] - Z
Sets up the data memory and draws the simulated LED cube on the panel.
Fc9-type-5-icon.png Output Pin
Pin used to drive the output to the buzzer
Fc9-type-1-icon.png Color
Controls the color of the Buzzer object on the panel.
Fc9-conn-icon.png Simulations
